Slee part time kit??
The Old Pueblo
clownmidget said:
Ah, he'd still need to have freewheel hubs to "truly" get that light front end feel.
Or remove the drive plates and make some bling Red Green approved caps.:D
clownmidget said:
Gary (Waggoner5) did this but his 80-series drivetrain is sitting inside a 45 (https://forum.ih8mud.com/showthread.php?t=34899)
What are you hoping to gain?
Well I'm guessing here, but a little better MPG, more power to the rear wheels (that might make it more fun zipping up annd down dirt roads) . More options like a 2wd low.
Except when wheeling, why do I need fulltime 4wd? We get less than 10" of rain a year and no snow. The roads are always dry.
So just looking for the observations of others on this to see whether or not it's a worthwile mod.
clownmidget said:
OMG LMAO :grinpimp:
Are those wheels chromed too! :rolleyes: I can hear Tattoo "Boss, Da Bling! Da Bling!"
LandCruiserPhil's mega bling!:grinpimp:
The bad part is, the week before breaking that burf he took the locking hubs off!:doh:
LandCruiserPhil, Robbie and a few others have done the RWD thing and reported not much gain, search. I like the AWD, for 2WD it's more fun to go FWD, get some bleach and do big smokey burnouts!:D
just a rebadge kit from Marks adapters, funny how people claim ideas that they did not devolop. Does not really gain that much. I really would not go this way, I like the system I have currently. I can have full time when I want it, part time at a inconvience (meaning I have to install and remove the drive shaft). lock the center if I have the drive shaft in. Best of all worlds,, but not super convient. The steering is lighter, wheels will follow the crown, and any groove in the road. the difference n fuel is aobut 2 miles on a average gain, how may dollars or ROI will pay off the 500 dollars and your labor (if shop lookiing about 4 + hrs) installed . That is a bit of dollars of fuel. later robbie
The center diff lock becomes the 2wd/4wd switch. I agree with Robbie on the usefullness of the kit, although when I did the driveshaft removal, CDL, and manual hubs, I gained 0 MPG. I am a little heavy footed though. I expect my 45 to be very different driving than the 80 series. The main reason I did the part time kit was that first, Christo made me a deal on it, second, I was in the tcase anyway doing the crawl box, and third, will be doing a lot of flat towing of this truck if it turns out the way I expect. With the transfercase really in neutral, with no coupling, and the front hubs unlocked, it should flat tow like any other early Cruiser.
The argument of driveability and fuel economy improvement for this conversion is still no good for me. I think it will be for the someone that just wants 2wd. My supercharged 80 with no bumpers to weigh it down ran only marginal. In 2wd it would hardly untrack the rears. I drove several trucks supercharged like mine and they ran similar. Don't get me wrong, the supercharger makes a big difference, but 185 ft lbs. at the rear wheels on a 6k lb truck with all wheel drive is what it is. And....my point being is that 2wd made little difference.
Whats up Robbie? Thanks again for the help in Moab.
G
I drove my rig around for about a month and a half with the CDL locked and the front drive shaft out. The front is more nimble, and actually at high speeds it wanders a bit more than if in normal driving mode. I did not see a difference in gas mileage or power.
I thought for sure it would put more power to the rear wheels. For you guys who didn't notice any added power, is your motor and intake/exhaust stock?
I already have a noticeable gain in HP from opening up my exhaust and turning up the timing. I'm running HI flow cats and a flowmaster 40 series muffler and 2-1/2" pipe from the cats back. Timing at 10deg. The rig really takes off now, and I figured if it was 2wd I could get some good drift going on dirt roads and have some more fun driving it. I also figured by not sending power to the front I should get better MPG. It seems, though, that the consensus is the kit is worthless.:confused:
Open center diff. 4lo is an incredibly easy mod on a 91-92; don't know about later years.
You seem curious enough about the 2wd idea that you really should, as already suggested, pull your front driveshaft for a while and see what you think. Doooo it! :D
Curtis
The kit does one more thing. It saves wear and tear on the front end components. It was never intended for everyone. It is for people like Gary that wants it for a specific need. Also, if you have a viscous coupler that is failing this helps you with removing it and not have to be in 4wheel drive all the time.
Also, there are hard core wheelers out there, and this will help them to get off the trail if they break front end components and do not want to spin the front diff/birfields etc etc. Yes it call can be done by pulling parts and pieces, this makes it easier.
I have blown @&@&@&@& up on my other trucks and its no fun fixing stuff in the bush just to get out. You end up doing the same job twice because you couldn't do it right on the trail.
Quote slee
"Also, if you have a viscous coupler that is failing this helps you with removing it and not have to be in 4wheel drive all the time."
If you remember from our discussion in the past at the shop, the viscous coupler can be remove with effecting the function of the center diff.The viscous coupler is a add on and is not really necessary in the function of the center diff.
So I do not really understand your statement and what you are trying to say to the group. robbie
