Slee Carrier Hi-Lift Holder Problems (any tricks??)
Discussion in '80-Series Tech' started by Boston Mangler, Aug 27, 2006.
  1. Boston Mangler
    Boston Mangler
    3,589
    4
    May 21, 2004
    San Diego
    Slee Carrier Hi-Lift Holder Problems (NOW FIXED)
    Hey Guys
    I got my slee rear bumper on and everything is top notch for sure.
    The one problem/question i have is the hi-lift holder. I mount it up as it is supposed to be and it does not stay in place. It rotates on the stud that holds the jack to the carrier and slides out of the base plate.
    Anyone else experiencing this? Any tricks??
    Thanks
  2. clarkrw3
    clarkrw3
    1,595
    Albums:
    1
    Nov 29, 2004
    Tempe, AZ
    How are you mounting it? I have never had problems but also mounted it wrong for a while. The right way to mount it is with the lift plate in toward the tire and the lifting bar away from the tire. The bolt goes btw the lifting lever and the hi lift I beem and not threw a hole in the I beem. then the curved part of the plate goes around the lifting bar andthe L portion pushes down on the I beem portion. Let me know if you need a pic...or if any of this makes any sence.
  3. Romer
    Romer fatherofdaughterofromer Moderator
    10,850
    2,140
    Sep 14, 2003
    Centennial, Colorado
    clarkw3 is correct. It seems like the bolt should go through one of th holes. Took me about 15 minutes to figure it out. No issues since then
  4. Boston Mangler
    Boston Mangler
    3,589
    4
    May 21, 2004
    San Diego
    yes, if you could snap me a pic that would be awesome
    i feel like a retard
    thanks
  5. Boston Mangler
    Boston Mangler
    3,589
    4
    May 21, 2004
    San Diego
    Gotcha, you are 100% correct, i just tried this and it works fine, the hilift doesnt budge, very stoked now! I love easy fixes! :D
    [​IMG]
    and
    [​IMG]
  6. Boston Mangler
    Boston Mangler
    3,589
    4
    May 21, 2004
    San Diego
    Yes, that is what i thought and how i installed it, all better now! Very sturdy!
    Thanks to all for the advice!
  7. Grench
    Grench SILVER Star
    2,801
    96
    Jun 15, 2006
    Omaha, NE
    Now you're ready for the next trick. Get a hi-lift cover and punch two 1/2" ID gromets into it at the right height to fit.
