- Thread starter
- #21
Pics would be super helpful! With all the responses I'm starting to hone in on what I want to do.I went with two Interstate batteries, both AGM. The aux battery is the Interstate MT7-75DT AGM...it's the one that the battery tray was designed around. This was my first electrical project of any kind and the planning was the most challenging part. Once I started the actual build it came together easily and nicely. I've got a few pics that I can message you if it would be helpful.
This is looking like the best short term plan.This is my setup and I've had no issues.
Stock battery/tray + Slee second tray and yellow top optima + 100w Renogy + Controller.
Its wired like this:
Alternator to the Stock battery to Blue Sea ACR to the Second battery (Slee tray & Yellow top) to Charge Controller to Renogy 100w Panel.
With several circuit breakers and fuse box in between those of course.
So, this is how I think my set up is working or seems to work, I have a monitor where I can see when the AUX battery is charging.
When the truck is running and the stock battery reaches 12.4 volts ACR opens and starts charging the AUX battery. Vise versa when the truck is not running and the solar panel is charging the auxiliary and it reaches over 12.4 volts the ACR opens and starts charging the main battery. Since I've had this setup both batteries start at 12.9 volts.
