slave cylinder clutch (6.5 chevy) (1 Viewer)
canmore AB
So here's the story, truck went in for some work glow plug's oil change etc.. in the process of all the work the shop called and said the slave cylinder was leaking, they asked if i would like it replaced and i said yes.. So they replaced it. So when i got the truck back the clutch pedal was really soft so i went back and said can you check this for me, they bled the slave again and it was all right but now the clutch pedal is getting real hard to push in so i'm going to bring it back again, i'm just woundering if the clutch is starting to go?? Or is the slave cylinder gone bad .:confused: :confused:
kevin
Hmmh, they replaced only the slave? At my shop it's a no-no to change one or the other(master or slave)I always swap both at the same time and get the parts at GM. The assembly comes in one piece w/ fluid already in it and ready to go. Just snap in and your done. I got tired of come backs w/ the one or other method. The new fluid seems to shock the old remainder.
Similar threads
