Need to get started on landscaping around the house and want to install a sprinkler and drip system. Any tips or components to recommend or shy away from?
Fairly small lawn area ~1500 sf with ~80 lf of flowerbed/planters and couple of evergreens in back yard. Mostly xeroscape/hardscape in front with a couple flowerbeds planned. Thinking 4-6 zones would do it for the yard and the windbreaks will be on a yard hydrant without a controller - just tubing and emmiters.
Need to run ~450 feet of tubing for windbreak shrubs and trees. I have two yard hydrants installed so total tubing runs are around 150' Is 1/2" big enough for this? Water source is private well with a 30gpm 1.5hp submersible so water availability is no issue. More gpm is actually better in this instance to keep the pump from short cyclling.
Thanks!
Thanks!
