Skid Plate Advice Needed
Discussion in '100-Series Cruisers' started by cpainter, Dec 5, 2018.
  1. cmck
    cmck
    771
    Media:
    2
    Albums:
    1
    1,202
    Dec 29, 2014
    I have been beating on my slee aluminum for 2 years and am amazed on how well it is holding up.
    Cola and uzj100 like this.
  2. Skidoo
    Skidoo
    989
    Media:
    28
    Albums:
    5
    293
    Aug 25, 2008
    Sacramento area, CA
    A lot of places you could do without skids, 100s in the Hills, Death Valley, etc.
    On Moab level 5 or higher trails a front skid starts to be important.
    Now if you like to run real fast on smoother trails and come around a corner to find some BIG fallen rocks in the road, you might want a steel front. Know I was glad I had a steel front, have a good size dent in mine to remind me.
    I run Slee steel front and Dissent alum middle and rear. Have had the Slee on since 2008 and put on the Dissent ones this year.
  3. Joe Bob
    Joe Bob
    177
    Media:
    3
    Albums:
    1
    275
    Dec 5, 2015
    Lincoln, CA
    Do you have pics of the current condition after the 2 years? Wa hat was the most significant impact that you have had on the sliders?
  4. cmck
    cmck
    771
    Media:
    2
    Albums:
    1
    1,202
    Dec 29, 2014
    I get some photos this weekend of the front skids.
    As far as sliders they are slee steel ones and have come down hard on rocks many times and carried the full weight of one side of the cruiser. That's the "proper" use of a slider.
    They are not dented but have scratches or deep scratches on the underside of the tubes. I touch up with paint seasonally.
  5. uzj100
    uzj100
    6,603
    1,675
    Jun 18, 2003
    Raleigh, NC
    I have Slee sliders that have been beat on hard and only have scratches.
    cmck likes this.
  6. Ole Colony
    Ole Colony
    225
    60
    Jun 15, 2012
    Lafayette, LA
    I have the oem one if you are interested in buying it.
  7. kruisinkid
    kruisinkid topless dorkel SILVER Star
    1,598
    211
    Jul 23, 2013
    BK/PA
    anyone have any pics and prices of the dissent skids? they are not listed on his site. i have been looking for the rear most OEM splashguard because its partially cracked off. i could be convinced to go aftermarket alum or steel if i had some more info. thanks!
  8. hoser
    hoser SILVER Star
    8,988
    1,242
    Dec 21, 2003
    Bay Area, CA
    Edit: I need to figure out how to fix these...
    SmoothLC likes this.
  9. cpainter
    cpainter
    9
    5
    Aug 3, 2018
    Brady, Tx
    Thanks for the offer, but I'm probably going to bite the bullet and order all 3 plates and just get it over with. The middle plate broke in half a few months ago. It looks like it was just made of plasticized fiberglass of some kind. I'm looking pretty seriously at Bump It Offroad along with Dissent (still my favorite). Anybody have any good or bad experiences with the TJM skids?
  10. cpainter
    cpainter
    9
    5
    Aug 3, 2018
    Brady, Tx
    Started a conversation with ya...
  11. abuck99
    abuck99 SILVER Star
    2,544
    1,553
    Nov 8, 2015
    ATL
    Dissent offroad aluminum and steel skid plates.
    kruisinkid likes this.
  12. abuck99
    abuck99 SILVER Star
    2,544
    1,553
    Nov 8, 2015
    ATL
    Those are some interesting lateral scrapes..... looks like Slee mid plate. What happened?
  13. hoser
    hoser SILVER Star
    8,988
    1,242
    Dec 21, 2003
    Bay Area, CA
    They are Slee plates and about 7 years old. Not any one particular incident. Several layers of touch up paint. But they do take a beating. If I can straighten them out, I will try and add some reinforcements. 100s are heavy.
  14. chuckscap
    chuckscap
    269
    79
    Apr 5, 2015
    I have the full set of BIOR skid plates like them a lot.
  15. Skidoo
    Skidoo
    989
    Media:
    28
    Albums:
    5
    293
    Aug 25, 2008
    Sacramento area, CA
    If you are only wanting to replace that splashguard, probably just want the middle plate. The rear plate for Dissent and Slee cover stuff behind it.
  16. Skidoo
    Skidoo
    989
    Media:
    28
    Albums:
    5
    293
    Aug 25, 2008
    Sacramento area, CA
    Have had my Slee sliders and front skid for 10 years. Have run most trails in Moab area, San Rafael Swell, San Juan Mts, Death Valley, etc. Want to meet up in Roseville sometime to look them over? PM me.
  17. SmoothLC
    SmoothLC
    1,999
    598
    Feb 6, 2010
    SLC
    If you get all three plates from Slee, just be aware that you may have to modify the belly plate depending on your sliders.
    The Slee belly plate requires some modification with the MetalTech sliders.
    Obviously all Slee components fit together, but something to consider.
  18. abuck99
    abuck99 SILVER Star
    2,544
    1,553
    Nov 8, 2015
    ATL
    ^^ Depends on which MT slider,
    The MT AHC slider (2 mount points) doesnt interfere with Slee skids.
    That said, I’ll note from owning slee skids a clear downside to their belly skid- its not designed for easy access to service the transfer case or the ujoint and slip joint. Access holes are so small that your hand wont fit through to undo filler and drain plugs. It makes a simple job a pita.
    The slee belly skid also replaces the TC cross member so any time you need to drop the transmission pan, do TC work, or remove the drive shaft you have to drop a 100lb belly skid and brace the TC. Another downside to the bellyskid replacing the cross member is fabrication accuracy of the belly skid TC mount. Any minor (fractional) variation in fab work will result in a misalignment of the TC- mine was slighty off- enough to raise the TC a few mm where it rubbed on a seam under the hi-lo shifter and made all kinds of noise. Required some effort to smooth out the seam and the replacement of the TC mount. Not a perfect design.
    I noticed the Dissent belly skid fits over the oem cross member- and from what I can see provides easy access to drain & fill & lube points. If you DIY maintanence, seems more user friendly from a service perspective.
    SmoothLC, Skidoo and kruisinkid like this.
