single ended rams
Mace
rock scientist..
Staff member
s-Moderator
Moderator
Las Vegas
That seems pretty cheap In considering hoe much the psc set up is. How do you figure the size ram you would need?
length of the throw is identified by turning the wheel all the way to one side, mark the tie rod at a specific place (like directly above the leaf spring) and then turning the tires all the way to the other side and making a mark on the TR. The length between those two marks is the actual throw that you need for hydro assist.
Size, if you don't mind a slightly slower turning rate at a stop sign, then the 2" works well. If you don't want to feel the assist at all, and can deal with slightly less assist, then a 1.5" ram is the choice.
Just to make sure Im reading it right, the link posted would be for hydraulic assist, correct? Dual acting meaning it uses pressure to extend and retract, right?
yes but you could use it for full hydro too.
