single 30 mm coil spring spacer (1 Viewer)
JAX, FL
man-a-fre now sells a single 30 mm coil spring spacers for the 100 series.. would it be safe to use these spacers with the 866's and with or without a steel bumper?
JAX, FL
Depends on how much you crank the front end, but 30mm is over an inch of lift.
i can still crank my ome torsion bar, but will lose the minimum down travel of 60mm.. my front end is in maximum lift already with the minimum down travel of 60mm.. is it safe to have less than 60mm of down travel?
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
