Simple rear brake job turned ugly
Decided to get my new FSM dirty last night. When removing the rear wheels to replace pads I had one lug on each wheel become stuck. DIfficult to turn either way and eventually snapped. :doh:
I'm assuming the tire shop had cross threaded with their air wrench?
More importantly, how the heck do I fix these?
If I'm understanding the FSM correctly I have to pull all kinds of goodies to replace the broken lug studs? Looks like there are a few non-reusables as well. Anybody done this before?
Don't know if the '94 is any different from a '97, but on the '97 you have to remove the axle shaft and caliper, then you can pull the hub. Replacement of the studs is by pressing them in/out. It'll just be more challenging to press those studs out since there's nothing left to press on :doh: I think you should be able to pound them out with a drift and a BFH.
I'm not sure if 94's are the same as 97. If so, all it takes is removing the caliper from the caliper mount (2 bolts). Then slide the rotor off the hub. Now you have access to the broken studs. A big hammer and a maybe a punch if there's not too much stud left to hit on, and they will pop out the back. to install new ones, you need a same thread lug nut but not the factory one. You need one with a hole on both ends, tapered on one end. Feed the stud from the back, stack somne washers on the front side, then screw on the lugnut, (with the taper facing the washers.) Now is where the impact gun comes in handy! Just tighten it until the back of the lug nut is flush with the hub. Anyway, that's how we do it at my shop, and I had to do it on my rear hub once also. HTH!!
[quote author=offroadkid link=board=2;threadid=14216;start=msg132495#msg132495 date=1081089955]
I'm not sure if 94's are the same as 97. If so, all it takes is removing the caliper from the caliper mount (2 bolts). Then slide the rotor off the hub. Now you have access to the broken studs. [/quote]
Pretty sure it's not quite this easy. Possibly for the front, but not for the rear.
It looks the same in the pic as mine does. If you have prob's getting the rotor hat off, there's two threaded holes opposite eachother between the wheel studs that allow you to screw bolts into to loosen it from the hub. Just tighten evenly on each one, and it should pop off.
I just had the same exact thing happen to my truck and yes it is the same procedure as a ‘97. This link created by Chris should assist you in getting things up and running http://65.40.131.223/fzj80_rear_bearing.htm . Now that that happened I use anti-seize on all the lugs and torque them down to 109 ft. pounds. (specified for a ’93). The only snag I ran into was trying to find someplace that stock this tool http://toyota.spx.com/detail.asp?partid=525 .Oh wait and another snag of getting the wrong stud, they kept wanting to give me the shorter lug (p.n. 90942-02049) when I needed the correct slightly longer (p.n. 90942-02052) in addition to giving me a gasket for the hub that came pre-ripped in half. Do yourself a favor and just order the correct parts from C-Dan instead of wasting time at the local place.
You have to pull the axle, then the hub/wheel bearing assembly. Then you can press out the old ones and press in new ones. They can be done at home with a hammer - it's not rocket science but you need to be sure you beat the heck out of them to seat them fully. You should replace them all rather than only broken ones. Obviously, this is going to mean the rear wheel bearings (most mechanics aren't even aware 80s have the repacking need here) will get repacked, and new axle seals so it's a good maintenance opportunity. I agree you should have Cdan set you up. This is no time to have the vehicle sitting because someone sold/ordered you the wrong seal.
DougM
I disagree. I don't think it's necessary to pull the axle out ??? There's enough room behind the hub to knock the studs out. I did mine during my 1/2 hour lunch break. Of course I had a hoist and airtools, but all I needed to do was remove the wheel, remove the caliper, rotor, knock-out the broken stud, insert the new one and seat it. Unless there's some big difference between your 94 and my 97 it should work the same way.
No where to get parts on Sunday so I haven't been able to do anything. Unfortunately I'm heading out of town on a business trip early Monday so my plan is to drop it off at the dealer on my way. I'll need the truck Friday so I don't have much choice. If their price is insane I'll call C-Dan Monday and order what I need. Looking at the FSM it sure looks like you have to pull the axle. Really sucked last night at 11pm when they broke. Such a simple thing to go wrong. My friend from El Salvador was helping, he got fired up, went all Ricky Ricardo and everything, wasn't a pretty sight. Anyone care to take guess at what the dealer will charge? My guess is $250.
Thanks for the help,
Jason
MOJ, ORK's shot cut sounds very good, all you will need is the new stud and a nut of the propper type, I would think less than $10 in parts and 2 hours or so of your time
save the rear bearing repack for the next free time you get
I had to replace one as well. There is plenty of room behind the Rotor/Drum to get the old stud out and the new one in. You'll have to pull the rotor/drum. No need to press the new one in either. Just get it started the best yo can and it will suck up when you tighten the lug nut up at the end. Get the parts on order and do it yourself, won't be more than an hour a side. You still have 5 lugs on each side so on road driving should be fine if you didn't have time to get them in before friday.
Hey, that's a good trick to know ORK. I was just sitting here thinking about it and realized the rear rotors come off differently from the fronts as you note. They're held on by the wheel and a few hammer blows generally will get them loose. And from what you say there must be a point you can rotate each stud to that clears any shields and other surrounding items to swing a hammer to pound it back in, eh? Good call!
DougM
Yeah? Hmm. I never tried it as I had all 12 rears replaced as PM when I pulled it all apart for wheelbearing and axle seal replacement. I won't have to worry about this any more as I'll never have anyone touch the lugnuts since I got winter wheels at the same time so I can change them myself twice a year instead of paying someone else to remount tires....
Doug
