signal lite / finish
Discussion in '80-Series Tech' started by ChiTown LC 96, Oct 31, 2005.
  1. ChiTown LC 96
    ChiTown LC 96
    2
    Oct 17, 2005
    Newbie here - let me first say that I enjoy this board and have gotten some great info from you guys/gals...
    A couple basic questions for anyone:
    1. I need to replace my front orange signal lite (the big one next to the head lite) - what is involved?
    2. Unfortunately I recently parked under a railroad pass and some brown gook/liquid of some sort rained on my '96 LC! I was a little overzealous in rubbing it out in some spots and I am afraid I may have done some permanent damage (I hope not) to my finish in a couple small areas on the hood. Is there any product out there that may help or did I royally :censor: up !?!?
    Thanks in advance!
    ChiTown LC 96
  2. Romer
    Romer fatherofdaughterofromer Moderator
    11,058
    2,678
    Sep 14, 2003
    Centennial, Colorado
    1> You should buy an FSM (Factory Service Manual) it will tell you how to do this. On my LX450 (Different front lights) its fairly simple by taking off brackets, but the FSM would tell you
    2) Take it to a professional shop and ask them to buff it. Don't try it at home.
  3. Whipp
    Whipp
    114
    Oct 15, 2005
    Gilbert, AZ
    For your signal light, open your hood and look above the light. There's only one screw you need to take out, a phillips head, if I remember correctly. The whole marker light assembly then pulls forward and out. The bulb holder twists off and pulls out of the back of the assembly. I don't think you even need to disconnect from the wiring harness.
    No clue on the paint finish. I'd have a shop look at it.
    - Craig
  4. alkaline747trio
    alkaline747trio
    4,577
    13
    Feb 2, 2005
    Albemarle NC
    The light assembly might be hard and contrary to come out, so use some force, you're not gonna break it...
    About the paint, get a professional to buff it, and then you might need some touch-up paint. Ask CDan about what your color would be.
  5. Beowulf
    Beowulf
    12,529
    68
    Mar 27, 2003
    Somewhere in the foothills...
    The following images are on Christo's web site.
    [​IMG]
    [​IMG]
    -B-
  6. Bear80
    Bear80
    3,019
    Media:
    12
    Albums:
    1
    71
    Sep 23, 2004
    What did you use to take the goop off with? Bug and tar remover, or a polishing compound?? And what is exactly the problem with the paint, scratched, rubbed thin?? If you didn't get all the goop off try some bug and tar remover, it's labeled as such in any auto parts store and probably wally mart. If you used a rubbing compound and you suspect the paint to be thin then there isn't much a professional shop can do other than repaint it. Let see some picture of the hood. And on that note some pictures of your ride...welcome :flipoff2:
  7. ChiTown LC 96
    ChiTown LC 96
    2
    Oct 17, 2005
    Thanks for all the replies - unfortunately I don't have any picts.
    Gook was a bad description - it was more of a liquid rust stain. (kind of like what a tree leaf imprints on your car)
    I used Armor Car Wipes and I think I just rubbed to hard with my finger tips.
    It sounds like I need to take it to a Professional Car Cleaning place and see if they can buff it out.
    Thanks again for all your help!
