Hi, my drivers side mirror only tilts about half as far as it used to when reversing. Any ideas about where to start on fixing?
Thanks.
Thanks.
Thanks.
I have the same issue as @geanes . I ended up turning mine off. It would be nice to have a fix.My passenger mirror does the same thing. It doesn't tilt all the way down and it doesn't return to the correct position. It seems to work fine manually though. I had to turn off this feature because of this issue.
Check your mirror adjuster knob. It has 3 settings: Left, Right and Center. If the selector is in the middle, the reverse-dipping is turned off. Flip the selector to either Left or Right.if you find out, please post the solution since mine doesn't tilt at all.
Yes. That sound similar to mine. The passenger mirror has full travel, but the driver's mirror only moves about half as far as it used to. It has full travel when I manually move it up and down.My passenger mirror does the same thing. It doesn't tilt all the way down and it doesn't return to the correct position. It seems to work fine manually though. I had to turn off this feature because of this issue.
You are the man... I couldn't figure out why it was working the other day.Check your mirror adjuster knob. It has 3 settings: Left, Right and Center. If the selector is in the middle, the reverse-dipping is turned off. Flip the selector to either Left or Right.
