Hi y'all, nothing in the FAQ and search on the subject, and no info in the 2F FSM that I can see. Where is the side cover install procedure? Mine is off, cleaned up, and ready to go back on. Someone said 39 in*lbs on the screws... Do I use any FIPG or sealer on the Toyota stock gasket (cork I think, by appearance). Do tell...
Cover cleaned, old gasket was really baked on there, had to scrape with a razor and scrub like hell with wire brush, then a couple purple cleaner baths. Got new PCV valve & grommet to use as well.
Engine surface is easier to access if you pull all the other crap. Doing an oil change and Trollhole dissy install at the same time so it was a good time to do this as well... Got the mating surface on head pretty clean and accessible.
