Shudder on Steering Wheel and Foot Pedal When Braking - Not What You Think
Discussion in '100-Series Cruisers' started by MH_Stevens, Jun 13, 2018.
  1. MH_Stevens
    MH_Stevens
    686
    20
    May 24, 2005
    Bonsall, California
    My truck (2007 with 200K miles) has always had a bit of this - shudder on steering wheel and brake pedal when braking. Normal cause of this is warped rotors or other brake issues, so I had complete new brakes all around. New rotors, calipers and pads. And new rear shocks.
    Seemed to be OK for a while but now shaking is back and is violent when braking going down hill.
    Anyone got any ideas for me?
  2. fjcruising
    fjcruising
    72
    Media:
    1
    Albums:
    1
    16
    Feb 24, 2007
    Hmm... always start with the basics.
    When you did the brakes (rotors, calipers and pads) did you do both rears and fronts?
    How long is a while? 20k miles? 40k miles?
    Do you tow?
    More complex:
    What kind of brakes/rotors did you get?
    These are heavy trucks, they use a lot of brakes - depending on your driving it isn’t unusual. Hope we find something that solves your issue.
  3. YardPig
    YardPig SILVER Star
    917
    191
    Dec 3, 2009
    Shawnigan Lake, B.C.
    I've had rotors out of the box 'warped'. Rotor's don't warp, it is pad material impregnated into the rotor that causes the pulsation. What brand of pad/rotor did you use?
    willbt likes this.
  4. Madbodhi
    Madbodhi
    110
    176
    May 6, 2016
    Wisconsin
    What do your wheel bearings look like. I had an issue awhile back that I was certain was the brakes. Turned out to be a fried wheel bearing.
  5. Tanner H
    Tanner H
    189
    Media:
    1
    173
    Nov 3, 2015
    Corona, CA
    I would look into wheel bearing play, tie rods, steering rack.
  6. MH_Stevens
    MH_Stevens
    686
    20
    May 24, 2005
    Bonsall, California
    All brake bits were NAPA generic types. If its a wheel bearing problem would that be a front? How do I diagnose tie rods and steering rack?
    Thanks for the input.
  7. bluesquirrel
    bluesquirrel
    231
    190
    Feb 24, 2017
    Phoenix, AZ
    My wife's car had the same issue. I thought it was brakes, but it turned out to be a wheel out of balance. Might check those
  8. BillZ260
    BillZ260
    479
    Media:
    83
    194
    Oct 26, 2016
    Tulsa, OK
  9. YardPig
    YardPig SILVER Star
    917
    191
    Dec 3, 2009
    Slap another set of rotors on it.
  10. AimCOtaco
    AimCOtaco ...---... SILVER Star
    1,385
    Media:
    55
    Albums:
    1
    356
    Aug 2, 2010
    Longmont CO
    Changing the front rotors requires that the bearings come off with the hub and have to at least be adjusted properly (if they've been maintained otherwise) and depending on who did that work I would check those first. Could be lots of things, how is all the suspension rubber in the control arms front and rear?
  11. Spike555
    Spike555
    1,824
    755
    Jun 23, 2016
    Wyoming MI
    If you are one of those "drive it like you stole it" people and always brake at the last minute you will warp rotors quick, even new ones.
    I'm not saying that you are that type, I'm just saying...
  12. MH_Stevens
    MH_Stevens
    686
    20
    May 24, 2005
    Bonsall, California
    Spike555 you are right, but its my WIFE who drives like that! ALSO just checked my records and I ONLY changed the rear rotors not the front so I guess I do that first and check wheel play while i'm there.
  13. Tanner H
    Tanner H
    189
    Media:
    1
    173
    Nov 3, 2015
    Corona, CA
    ah man. there you go. report back after new rotors.
  14. TheAshenWolf
    TheAshenWolf SILVER Star
    135
    64
    Sep 15, 2017
    Littleton, CO
    I had a similar problem on my 99. Repacking the passenger side wheel bearings did the trick.
  15. RootMeanSqr
    RootMeanSqr
    148
    75
    Jan 5, 2016
    SoCal
    So are you saying there's a possibility that it IS what we think? ;)
  16. MH_Stevens
    MH_Stevens
    686
    20
    May 24, 2005
    Bonsall, California
    Yes. I'm sorry just blew my mind when I discovered I had only done the rear and not done the front bearings either.
