Show me where the starter is
Discussion in '80-Series Tech' started by Mudshack, Jul 6, 2005.
  1. Mudshack
    Mudshack
    422
    Mar 23, 2004
    Lee's Summit, MO (KC)
    I am having the same problem everyone else runs into. The starter that works when it wants too. I want to replace the contacts and plunger, but don't know where they are in the truck. Please send a diagram. You can email it to jmaruschak@othon.com
    Thanks.
  2. Boston Mangler
    Boston Mangler
    3,589
    5
    May 21, 2004
    San Diego
  3. Mudshack
    Mudshack
    422
    Mar 23, 2004
    I expected that. And deserved it. Some day I will break down and buy one. Only problem......I will be tearing into EVERYTHING then! And will be divorced.
  4. 97 FZJ80
    97 FZJ80
    1,539
    Albums:
    1
    9
    Jun 3, 2003
    Plano Texas
    It's under the engine on the driver's side. One bolt is accessible from the driver's side wheel well and the other from the underside.
    If your LX is anything like mine, the starter was put in by a 500lb gorilla and I could not loosen the bolts after soaking them for 48hrs and using a breaker bar with a 48" cheater extension!
  5. TLCgrappler
    TLCgrappler
    135
    Mar 31, 2003
    The starter is in the drivers side of the engine, lower down, and back towards the firewall. The Transmissions filler pipe gets in the way a little so follow the transmission filler pipe down and you should see the starter. For some reason it tends to stay shinier than most under the hood items.
    Its not complicated to remove, but I ended up just replacing it with a rebuilt one in the interest of time. Then I bought the contact kit from Cdan so now I can have a spare one to plop in after another 90K or so.
    BTW, the $ for the FSM will absolutely be the best ones and highest return on spending that you get.
  6. Mudshack
    Mudshack
    422
    Mar 23, 2004
    TLC, I agree on the FSM. I love it, and would have it sitting on the back of the throne for those long breaks away from the kids. I just have to break down and buy one. Haven't yet, and the starter is only working about 40% of the time on the first crank. And it flat out sleeps with repeated cranking about 10% of the time. A little embarassing when taking clients out.
  7. Beowulf
    Beowulf
    12,529
    68
    Mar 27, 2003
    Somewhere in the foothills...
    Mudshack,
    You will be more embarassed when the thing leaves you and your clients stranded. A failing starter needs to be fixed ASAP.
    You can spend $10 and download all of the manuals from TIS or just pull down the starter section if you are in a pinch for time.
    -B-
  8. Tools R Us
    Tools R Us
    23,743
    5,483
    Jul 20, 2004
    Chandler, AZ
    It's not that bad of a job, removing the wires first gives you more room to get the top bolt. I did it all from underneath, the starter slides out the bottom between the frame and motor. Don't know how tight the bolts were, pulled them with a 3/8" impact, the top bolt took a 6" extension and the bottom took a 3" with a universal.
  9. 97 FZJ80
    97 FZJ80
    1,539
    Albums:
    1
    9
    Jun 3, 2003
    Plano Texas
    When my starter was acting up, I carried a box wrench in the door pocket - to remove the battery connection quickly when the starter contacts fused...
  10. Boston Mangler
    Boston Mangler
    3,589
    5
    May 21, 2004
    San Diego
    Ditto That! I learned that firsthand! I got my FSM and through many nights on the crapper, found all sorts of cool stuff that needed to be "Fixed"
    The FSM has helped me a lot, but also made me spend $ on stuff the probably didnt need to be done! Oh well! Its fun!
  11. Mudshack
    Mudshack
    422
    Mar 23, 2004
    MMM....beo...what is this TIS you speak of?
  12. elmariachi
    elmariachi
    1,977
    23
    Jan 4, 2005
    Shufflin' Through the Texas Sand
    You continue to sport that Lone Star Land Cruiser avatar, yet you don't attend any LSLC meetings nor call the other "Lone Star" members in your area for help. So I found you a new avatar, more indicative of your "independent" and "individual" style:
  13. Mudshack
    Mudshack
    422
    Mar 23, 2004
    I wondered how long it would be until you gave me some sh*t Jim. How ya doing? Been a while.
  14. elmariachi
    elmariachi
    1,977
    23
    Jan 4, 2005
    Me and my FSM are still spending time together in my garage. :flipoff2:
    I have a deal for you. You supply two sets of starter contact parts from CDan and I'll supply the FSM, the tools and the garage and we'll do these together. I'll even call your house and ask your wife if you can come out and play. :flipoff2:
    And bring your $25 LSLC membership check.
  15. flintknapper
    flintknapper
    5,447
    2,198
    May 22, 2004
    Deep East Texas
    Jim, people tell me the same thing all the time. It's not that we're "independent", "individual" or unsocialable....we're just (self sufficient) and would rather help others... than to be helped.
    As soon as I get my parts from C-Dan I'm gonna see what I can "muff up" by myself! I should have waited for cooler weather.
  16. Mudshack
    Mudshack
    422
    Mar 23, 2004
    "I should have waited for cooler weather..."
    Spoken like a true texan. I tried to motivate myself to install the remote starter before the hot weather came (the reason for buying it). But no. I am only 75% done, and have to muster up the energy to wake up at 5am to work on the truck. Otherwise I fear the vultures will cook my well-done body.
  17. concretejungle
    concretejungle
    9,592
    804
    Oct 27, 2003
    North Cadillac
    I wish i had local board members like Jim around here. I would probably be a permanent fixture to Jim's garage floor.
  18. informationjunky
    informationjunky
    3,314
    Albums:
    1
    7
    Jan 30, 2003
    FYI the write up on slees site is a big help.
  19. snowwolfwarrior
    snowwolfwarrior
    226
    Nov 16, 2004
    Rochester kent UK
    check out my post on how to change contacts.....Mick.
  20. Beowulf
    Beowulf
    12,529
    68
    Mar 27, 2003
