I installed a 2.5" lift with springs, torsion bars, diff drop, extended sway bar end links and used aftermarket UCAs with 3 degrees of caster correction. I had it aligned today and these were my results. The tech said that's all he could do "because of the lift, but it would be ok".
I've not spent much time learning about alignment but from reading here I thought UCAs with caster correction should make it easy to get a normal value. And some members seem to have a preference for a couple degrees beyond normal of positive caster made possible by their UCAs.
Do I need to try a different shop or is this par for the course?
Thanks
Thanks
