- Location
- United States
I'm looking for the trim pieces(not sure what they're called) that fit the shorter running boards for my 66 FJ45.
thanx!
Craig
thanx!
Craig
Could his have been a 65, sold and titled as a 66?66 should be long running boards
That answers that ! Good observation Brian.It's possible. When I got the truck it had the short steps, but when I went to install them I did notice that it also had holes for what could be the long ones. Since I didn't have any long ones I welded up those holes that I wasn't using.
Simon in Oz sells a long running board modified to be short.
Landcruiser FJ25,FJ28,FJ40,FJ43,FJ45.1957-1964.Side Step Set. Restoration Part. | eBay
Toyota Landcruiser. FJ25,FJ28,FJ40,FJ43,FJ45. Restoration Part. They have been Laser cut to match the original, then folded, the corners have to be welded and ground off on the outside edges. 2 x Top Plates 2mm.www.ebay.com
Well they probably weigh ~8 lbs and you have to ask nicely to get international shipping, which won't make getting them Stateside quite so reasonable. The source supply of longer running boards must be finite too.That is great, and the price is very reasonable!
