rossl
I'm swapping parts in my '78 to newer since I'm looking to upgrade axle strength as long as I have things pulled apart. I thought I had things figured out, but in the last step of putting it all back together I'm coming up short for the birfield outer snap ring by about 1-2mm. The birfield is pulled completely out, but there just isn't enough room to put the snap ring on. Is there a length difference between the '78 wheel hub and the later hubs? My understanding was the main difference was the brake rotor, but I could be wrong. And the spindle should be same on all models.
I'm running Longfield axles, which should be the short birfield length. I'm running a stock '78 wheel hub and stock spindles, and trying to put on an Aisin HD locking hub.
Referencing this post:
It should be about 26-27mm to run a standard AISIN hub, and 35-36mm for the long body. I have about 25mm, which means the snap ring groove is just behind the locking hub gear and impossible to install.
Anyone know what might be going wrong?
Locking Hub (Aisin) Won't Seat after Upgrade to FJ60 Birfield
No, have not try to take apart. Base on what poser said, 3 options.
forum.ih8mud.com
