Shocks too short or too tall. Which one is worst?
Discussion in '60-Series Wagons' started by hightide, Mar 5, 2007.
  1. hightide
    hightide
    386
    May 23, 2004
    deep south TX
    I don't really know how much lift I got. Im guessing is about 2 inches of lift. I accomplished this by adding longer shackles and long AAL on al corners. Im looking to buy shocks to replace what look like original to the truck shocks. should i go with shocks designed for 1 to 2 inches of lift or 2 to 4 inches of lift. Any suggestions will be greatly appreciated.
  2. REKCUT
    REKCUT SILVER Star
    3,593
    Media:
    103
    Albums:
    4
    70
    Jan 5, 2005
    Rogersville, Mo.
    My thought would be to jack up the truck until the front tire hangs off the ground and then measure the maximum travel that the shock would have to travel. Then measure that against the extended lenght of the shock your lookin at. I also believe that a factory set cruiser should measure about 65 inches at the roof. Maybe its 68 inches. do a search as someone had that info on hear not to long ago.
  3. REKCUT
    REKCUT SILVER Star
    3,593
    Media:
    103
    Albums:
    4
    70
    Jan 5, 2005
    Rogersville, Mo.
    Found a thread that say 69.5 inches is stock height for a cruiser.
  4. hightide
    hightide
    386
    May 23, 2004
    deep south TX
    Ive been to MO. Did basic training in Ft. Leonard Wood Misery. Coldest Ive ever been in my life.
    69.5?! Im 70" (in the AM) and the cruiser is taller than me by more than a couple of inches, Ill have to measure when I get home. So what would you go with if uncertain? Longer or shorter shocks?
    Thanks for the input.
  5. agent orange
    agent orange
    2,227
    7
    Jul 8, 2005
    New Kent, VA
    I would measure the distance from the axle to the bumpstop, and find the longest shock you can run without having it bottom out. You dont want too long or too short, they both lead to bad things.
  6. hightide
    hightide
    386
    May 23, 2004
    deep south TX
    4 inches between front bumpstop and axle. Ive done a search and someone said that stock space is about an inch. so that puts me at about 3 inches. i think im goilg with 2-4 inch lift shocks. suggestions?
    gracias
  7. mtb_rider
    mtb_rider
    881
    2
    Feb 17, 2007
    Wilsonville, OR
    Well if you have 3" of lift, then that makes sense to me. :)
  8. hightide
    hightide
    386
    May 23, 2004
    deep south TX
  9. kling-on
    kling-on Kool Arrow
    5,478
    Media:
    12
    Albums:
    1
    98
    Apr 26, 2003
    Pimpin part in SanAntonio TX
    yours looks like mine an I have a 4 in lift so run the 3-4 in shocks
  10. hightide
    hightide
    386
    May 23, 2004
    deep south TX
    Wow 4 inches. I dont have the time or patience to do the flex test so im just going to calculate using space between bumstop and axle and that puts me at about 3. Im not planing on any more lift, maybe a 1 inch BL. Thanks all for input.
  11. agent orange
    agent orange
    2,227
    7
    Jul 8, 2005
    New Kent, VA
    Just make sure that if your shock is 3 inches longer it wont bottom out when the axle is on the bumpstop, thats all that matters.
