Shock pin orientation...
I may be over-thinking this...
In the process of doing the black pipe rear shock mount mod/repair.
I cut out my old top shock mount pins, welded in place and am getting ready to weld the black pipe to the frame. My ?
Are the top pins parallel to the ground, weight on or off, etc. Or is it good to go if I can get the shock hoops on? Does it matter much?
I can envision slightly larger loads on the pins if the angle is not correct, but can't imagine it being of any consequence for a daily runner/beater snowplow rig
Oh, if I didn't mention...it's a holy hell of rusty crap underneath this thing, already induced one seeping brake line with all my pounding and de-rustification efforts:bang:
Nice trick for removing shocks off the pins top and bottom... use a small three claw bearing puller...works slick:cheers:
Dave
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
Complete...
...it's a done deal, and it looks parallel to ground best I can tell with my subjective yet critical observation.
FYI...for me this job (though one :banana:) took about a day and a half between pulling it in, getting pipe, drilling, cutting out the old stuff, grinding and welding, and...I'm still not done putting in the two brake lines!
I dislike with a level of intensity...rust!
Mace, thanks for the reply!
Dave
