using the sst tool I end up with a negative number for my bottom shim --
pulling 10 pounds of preload to adjust for what will be probably 33's
I get a total 2.20 mm of shim thickness for my total shim thickness, a difference of 2.20mm between my scribed lines (measurement D). My bottom shim (E) would then be 2.20mm (D) minus 3.0mm.
-.80mm?
do i simply NOT use a bottom shim in order to keep my center and preload?
thanks in advance
-.80mm?
thanks in advance
