90360-10003 | Ball | $1.19 | 3 | $3.57 |
90501-14772 | Spring Compression | $4.00 | 3 | $12.00 |
Try this
90360-10003 Ball $1.19 3 $3.57 90501-14772 Spring Compression $4.00 3 $12.00
Hey thanks !! I just called them and all they said they had was the 31mm longer one and that was all he was showing.I went through this same exercise, but needed the longer springs. Cruiser outfitters has kits with the shorter springs. Thankfully, I still had the longer springs, just needed the balls. give Kurt at CO a call, they'll hook you up.
Hey it's cool. My one non broken spring measures 24mm, I'm just going to order the long ones and fab em down to size. Thanks again for all the help !Sorry Mate, guess they sent me the last three short spring packs.
Heck yes that would be tremendous! PM sent. Thank you!!If you want or need the shorter springs, I can throw them in the mail for you. PM me your address and I'll mail them out sometime this week.
Thanks again for the springs!! Unfortunately these measure 19mm so they're a little short, I need 24mm and I'm stumped on why I can't find them :-( I'll just have to order the 31mm and grind em down to 24mm. Anything I can ever do for ya just lmk..If you want or need the shorter springs, I can throw them in the mail for you. PM me your address and I'll mail them out sometime this week.
Oh no! Total bummer, sorry they didnt work out. Oh well, pass them on to someone who can use them.Thanks again for the springs!! Unfortunately these measure 19mm so they're a little short, I need 24mm and I'm stumped on why I can't find them :-( I'll just have to order the 31mm and grind em down to 24mm. Anything I can ever do for ya just lmk..
I definitely will ! Thanks again!!Oh no! Total bummer, sorry they didnt work out. Oh well, pass them on to someone who can use them.
Cheers
There's 3 of them & part# 90501-14029 lists the quantity as "2" so that threw me a red flag. One of the old ones hasn't completely broken and it measures 24mm long & 9mm diameter.Are you saying this Toyota part number won't work? 90501-14029 . It's listed for a 1981.
How do you know you need 24mm?
Idk, I guess that's possible. I'm going to call Toyota Parts Deal and see if I can get a measurement on the 90501-14029 springs.Could that old spring have collapsed some with age? Mine stuck up quite a bit and I used longer bolts to compress them and pull the plate down into position.
Some pics of my installing them "HERE"
