Shift assembly on the transfer case to change from high to low. (1 Viewer)
Houston
I have a mechanical question that hopefully, someone will be able to assist. Any tips on how to remove 36313J listed in the attached. This oil seal is part of the shift assembly on the transfer case to change from high to low. Mine is severely rusted so much so that the seal “casing” has deteriorated to the extent it does not exists. Any thoughts?
Thanks – Fred.
The seal and shaft are for front wheel drive, not high-lo.
Usually all it takes is running a flat blade screwdriver around the lip, like opening a can of paint.
