Shackle Reversal AND Saginaw...?
Discussion in '40- & 55-Series Tech' started by Hobbs, Mar 4, 2007.
  1. Hobbs
    Hobbs
    477
    10
    Nov 13, 2005
    Big Pine, CA.
    Is anyone running a S.R. with Saginaw P/S? I am curious if there are specific manufacture's kits for each that would work together.
  2. kc_chevota
    kc_chevota SILVER Star
    1,324
    190
    Feb 19, 2003
    Kansas city MO
    i have the old sr kit cant recall who made i of the top of my head, i think advance handeling or somthing like that. and did the saginsaw conversion my self following the tech tips. didnt have any real problems
  3. randle
    randle
    132
    Jul 26, 2006
    on the north side of town
    i would check into keeping the lower saginaw mount bolts in the bottom of the frame rather than hanging below. it requires recessing the box into the frame more, but keeps the pitman arm from interfering with springs on compression. i ran into clearance problems, and decided to not even do the reversal. i suppose it depends on the distance of your spring hanger to frame dimension.
  4. Hobbs
    Hobbs
    477
    10
    Nov 13, 2005
    Big Pine, CA.
    randle, sounds like a S.R. might open up the clearance between the pitman and spring. Did you fab your oun steering gear bracket(s) or purchase a kit?
  5. JGM
    JGM
    151
    Aug 30, 2005
    Scottsdale, AZ
    I think this is essentially the config that MAF suggests. I had Dave Gore (MAF supplier) do mine, and that is what he did.
  6. petescoffee
    petescoffee
    1,898
    51
    Dec 29, 2002
    Walnut Creek, CA
    MAn-A-Fre
    BTB
    Deckers or from Mudrak
    ETC.
  7. Hobbs
    Hobbs
    477
    10
    Nov 13, 2005
    Big Pine, CA.
    What/who is BTB ???
  8. 65swb45
    65swb45 Elder Statesman Supporting Vendor
    22,513
    7,313
    Apr 14, 2004
    818-953-9230
    I do NOT have one on mine, but have seen one recently that a buddy of mine did with the MAF SR and the PS plate setup that Poser, Orange and I all sell.
    THe extra width of the SR bracket interfered with mounting the PS plate flat against the driver's side framerail. His solution was to cut an additional 1/2 plate to put between the PS plate and the frame, moving the steering box 1/2" inboard from it's customary location.
    Hth
    Mark A.
  9. ranger
    ranger
    1,160
    6
    Jan 18, 2003
    Mountain Hole, Idaho
  10. camcruiser13
    camcruiser13
    6,978
    Media:
    3
    Albums:
    1
    28
    Jun 22, 2004
    sittin on the couch in UT
    get lukes (4x4labs kits) for sginaw
    and profitts for the sr
    very happy with this set up
  11. Tankota
    Tankota
    388
    May 4, 2006
    Olympia, Washington
    I mounted my box inboard about 1.5" by using a BIG piece of channel iron with a few mods to it ;) as my mounting plate.
  12. randle
    randle
    132
    Jul 26, 2006
    i fabbed my own from the template in the tech articles. my reversal plans included putting the stock spring hanger directly on the frame (no riser).
    i thought the clearance to the pitman on full right turn with a stuffed driver side spring looked a bit close. so i bailed out to try the scout saginaw setup instead.
    i love doing things twice
  13. Hobbs
    Hobbs
    477
    10
    Nov 13, 2005
    Big Pine, CA.
    cancruiser13, was there any extra spacing required for the P/S box with the 4X4labs and Profitts brackets?
  14. Hobbs
    Hobbs
    477
    10
    Nov 13, 2005
    Big Pine, CA.
    randle, how did the Scout set-up turn out?
  15. woooody
    woooody el Jefe
    1,419
    42
    Mar 14, 2003
    Napa, Ca
    Mudrak did mine 6 or 7 years ago. Mudrak and Decker get their plates from the same guy. Luke at 4x4 labs has the same type of plates.
    For the S/R, we just used a regular shackle hanger.
    The plates move the Spring hanger point forward about 1 1/2, which allows a flat mount.
  16. randle
    randle
    132
    Jul 26, 2006
    i'm not done yet. also, i'm not doing a reversal, thats giving me all kinds of clearance.
    :beer:
  17. camcruiser13
    camcruiser13
    6,978
    Media:
    3
    Albums:
    1
    28
    Jun 22, 2004
    what do ou mean, where?
    i tucked mine back into the cross ember as far as i could
