Shackle Lift question
Discussion in '60-Series Wagons' started by ChicagoFJ60, Aug 23, 2006.
  1. ChicagoFJ60
    ChicagoFJ60
    182
    Oct 26, 2005
    Chicago, IL
    How many inches can you raise stock front springs with shackles? 2" over stock? I recently got 2" rear ironman springs and want to leave the fronts alone, just raise it alitle with shackles. Should i raise the rear with shackles too??
    Nicholas
  2. bridges
    bridges
    440
    Media:
    3
    Albums:
    1
    13
    Apr 12, 2006
    Lago Vista, TX
    The rear ironman springs will give you more than 2", I got roughly 4 1/2" with CCOT 1 1/2" shackles adding about 3/4" of that.
    I think the rule of thumb is: lift of shackles = about 1/2 of additional length. As stated above, expect that my 1 1/2" longer shackles gave about 3/4" additional lift.
    If you don't see a lot of rocks (per warnings around here) I'd go with the Man-A-Fre shackle reversal kit. Bolt on setup to add about 2" to the front. If you do some rock crawling I think the lower front spring mounts tend to get hung up.
    Send a PM to alpendubber - I think he is in process installing the shackle reversal.
