shackle angle and rear end height (1 Viewer)
Connecticut
I just finished replaceing the rear leaf springs with OME dakar leafs on my 83 60.
the shackes are stock size. when i lowered the the truck down finally the rear end is sitting really high and the shacke angle is pretty steep .
how do I adjust the angle ? do i need to remove a leaf ?
the front is still stock I couldnt afford to do all 4 yet.
I wanted to keep the truck close to stock height.
any tips would be appreciated. I'd love to get the rear end down a bit .
thanks in advance
rover67
Boulder, Co
but if his springs settle they will be longer between mounting points making the angle worse... right?
The beet lab.
no, he said they were too steep, settling would work them towards a 45 degree which most consider optimal.
go flex it out, or stick a bumper/swingout tire carrier on it.
New Mexico
thanks in advance
I think that this may be part of the issue you are experiencing. Post up a pic so that you can get a second opinion on the shackle angle.
REKCUT
Rogersville, Mo.
What type of springs? Lift or stock height replacement. IF you have not changed the front springs yet then you cant expect the truck to sit in a normal position. If you went with no lift factory height OME springs then you will probably have 2 inches more lift in the rear as the front have dropped at least that much over the years. IF you went with a lifted setup then you could be off 4 to 5 inches and that is going to cause your truck to be off.
rover67
Boulder, Co
gotcha, I was thinking that they were folded up. I was thinking about it backwards. Never mind.
Washington, UT. The Promised Land
The OME springs have the same length when they are flattened out as do the stock leafs. They have a much deeper static arch and a tremendously deeper unloaded arch. Your stock shackles may invert in a forward position if you don't replace them with longer ones. That's what happened to me. The best cure is a shackle that is about two inches longer than stock and relocating the shackle mount inboard about the same distance. This will give you a smooth ride, even more articulation at full drop and it will eliminate the inversion.
Wile E Coyote
Out in the streets, they call it murder!
Western AZ
If the condition you describe is literally immediately after getting the truck back on it's feet....then perhaps it's just friction from the shackles being too tight. They can be over tightened enough to cause a decent amt of binding. I assume it's been driven some by now, has there been any change as of yet?
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
