Severe Dieseling
Discussion in '60-Series Wagons' started by boerboel313, Sep 13, 2017.
  1. boerboel313
    boerboel313
    858
    46
    Sep 28, 2004
    San Clemente, CA
    Just had my 2F rebuilt by Cole imports in Charlottesville, VA. All in all a good job.
    Drove it back to Richmond, VA at highway speeds without incident but when i tried to shut the 60 off, it dieseled for 30+ sec and filled the cab with smoke.
    I paid him $4000 and the truck isn't right.
    Any suggestions?????
    Got to drive it all the way to CA starting Saturday.
  2. boerboel313
    boerboel313
    858
    46
    Sep 28, 2004
    San Clemente, CA
    I should also mention that my 2F is desmogged
  3. Spike Strip
    Spike Strip Adorable Deplorable SILVER Star
    11,938
    1,935
    Nov 22, 2005
    Sucking Kalifornia
    Check if your ICS is hooked up / working.
  4. mattressking
    mattressking
    503
    627
    Nov 28, 2016
    Ventura, CA
    Oh geez, that's not good. What did they tamper with and why did it go in for work?
  5. ceylonfj40nut
    ceylonfj40nut
    329
    164
    Jan 11, 2015
    Dallas,TX
    ^^^x2
  6. FishTown
    FishTown Proverbs 27:17
    1,021
    Albums:
    1
    487
    Jul 20, 2010
    San Antonio, TX
    ICS = idle cut solenoid. AKA fuel cut solenoid. It's the solenoid valve that is on the carb. It'll be the only thing with wires coming off of it connected to the carb. Make sure it's plugged into the wiring harness. If it is, then you should test it.
    "Do a search for idle cut solenoid or "ics". you should test it by applying 12V to it to see if the solenoid is opening ("clicking"). The you can do the "green wire mod", ie. attach the negative wire directly to ground to see if the probem goes away. If so you have a bad wire or a bad emissions computer."
  7. boerboel313
    boerboel313
    858
    46
    Sep 28, 2004
    San Clemente, CA
    Thanks all, I'll check it.
  8. boerboel313
    boerboel313
    858
    46
    Sep 28, 2004
    San Clemente, CA
    Its a long story but This old replacement webet carb doednt have the cut off. The Mech days keep in gear and stall it out.
    I have my original carb which I might send to the guy on hete who rebuilds our carbs and have him rebuild and configure it for my engine, or contact Trollhole for one of theirs.
  9. OSS
    OSS SILVER Star
    262
    325
    Jun 30, 2017
    The Grease Pit
    Yes until you get it sorted out with the weber carb-
    Stopping a dieseling engine:
    1. E-brake pulled tight
    2. Clutch pushed in
    3. Transmission put into 4th gear
    4. Turn off ignition w key
    5. Instantly let out clutch
    This technique is fine & won't hurt anything.
  10. Landpimp
    Landpimp
    15,767
    1,755
    Mar 14, 2003
    Gig Harbor WA
    The cab smoke may be a dizzy venting issues from the a incorrect desmog
    NeverGiveUpYota likes this.
  11. boerboel313
    boerboel313
    858
    46
    Sep 28, 2004
    San Clemente, CA
    This whole situation is very frustrating.
  12. Saucerman
    Saucerman
    34
    Media:
    1
    Albums:
    1
    35
    Apr 10, 2017
    Powder Springs
    I am hesitant to reply as I am new here, but from my experience in the Aircooled VW/Porsche world...
    When an engine would diesel or run-on it was almost always 1 of 2 things. Like everyone said, the idle cut off solenoid. The other culprit was someone fiddling with the timing. Sorry about the problems pal.
    boerboel313 and NeverGiveUpYota like this.
  13. ceylonfj40nut
    ceylonfj40nut
    329
    164
    Jan 11, 2015
    Dallas,TX
    Note that the click test on the ICS (connecting the ICS directly to the battery to hear click) does not always mean the solenoid is working. Make sure the piston moves in and out when powered or not. Check to see if rubber oring on ICS is intact and pliable.
    boerboel313 likes this.
  14. Spike Strip
    11,938
    1,935
    Nov 22, 2005
    Sucking Kalifornia
    He has a Webber. No ICS on a Webber.
    The stock Aisan is a better carb for a 2F. Get it rebuilt by a Forum Carb Guru and that will go a long way to end the dieseling. Dieseling is caused by gas dribbling into the intake when ignition is shut off and being ignited by a hot engine (performance build?). The function of the ICS is to completely shut off the idle circuit at engine off.
    Or, kill the engine with the clutch.
    Mark A. in Burbank - Marks Off Road Home Page 818-953-9230
  15. ceylonfj40nut
    ceylonfj40nut
    329
    164
    Jan 11, 2015
    Dallas,TX
  16. NeverGiveUpYota
    NeverGiveUpYota Dare me. SILVER Star
    2,094
    1,439
    Mar 28, 2011
    East Hampton, CT
    Timing big culprit of deiseling. Check the distributor and the vent hose on the cap for the interior cab smoke.
  17. boerboel313
    boerboel313
    858
    46
    Sep 28, 2004
    San Clemente, CA
    Thanks all for all the great advise. Just drove it about 100 miles on the highway. When I got to my destination and shut the engine off there was no dieseling.
    Not to say it won't happen tomorrow.
    Who was the guy on here who everyone was sending their carbs too. It was Jim or C something?
    Thanks again.
