Get a diesel or stick to fords..
[/QUOTE
Thanks dude
Lol kinda was but thank you for the info I’m not considering crossing deep waters but just looking at what I need to protect my vehicle if I go threw water deeper than I suspectedSounds sarcastic but I'm serious. The gasoline powered 80s are not great for much more than shallow water crossings. You can add diff breathers and snorkels which night help a little but the ECU is down low behind the glove box. Once the electrics get wet things go down hill fast. Not being able to manually control the viscous fan helps ensure water is moved quickly to all the high areas on the engine bay.
Ok thanks man not looking to do crazy water crossing but just want the added protection if I do come across some water that deeper than suspectedAlso forgot remove the factory alarm because if it gets wet it will activate and you’ll be dead on the bank.
That's because they are basically submarine tanks.I check the owners manual for my '94 and surprisingly it does not mention anything about water crossings. I seem to recall that my range rover gave guidelines of not crossing water deeper than the mid-point of the wheels.
Mine got named The U-boat after that trip.That's because they are basically submarine tanks.
