polloelastico
I've completed a tune-up, including a refresh of the fuel delivery components, including FP regular, relay, filters, etc. It starts like a champ and fires up on the first crank when cold, but hot starts will crank and stumble for a bit. It always does start though, so this is not super critical. The last thing I"m doing is setting the timing, however I'm getting some weird readings.
I have a BlueDriver scan tool (the LSB2 model) and once warmed up and all accessories off that's giving me a reading of around 4-4.5 degrees, and then with the E1 and TE1 terminals shorted it drops to 3, which seems ok right? However, when I hook up my timing light I'm seeing the flywheel mark to the RIGHT of the 0 mark by about 3 degrees, so that would be -3?. When I short the service box terminals it moves even more to the right, maybe another couple degrees. That would seem to be significantly retarded, yes?
So the question is, what is the right answer here? It's a timing light with an advance on it, but it's configured to zero, so do I trust the light? Do I trust the timing marks? Do I trust the scan tool "live" readings?
How does it run? well, it's pretty slow and consumes a lot of gas...haha.
