SERVICE SPECIFICATIONS, FLUIDS: Land Cruiser (UZJ-, HDJ-, FZJ-, HZJ-100 series) (1 Viewer)
Website
www.linkedin.com
29Jun2005 (UTC +8)
Can this service specification info make it into the FAQ? I compiled this because I'm consolidating my LC maintenance info and it was easier to reference now. If there are any corrections, please feel free to tell me about it!
* I got this info from geniune Toyota publications & service manuals. Though I have the Haynes, Max Ellery, and other books, I didn't consult them for fear of getting erroneous info.
** FZJ- and HZJ- info to follow soon!
Vehicle: Toyota Land Cruiser (UZJ-100, or LX 470)
Engine model: 2UZ-FE, 4.7L v8 cylinder gas-engine
Fuel type: 96 RON unleaded, 96L
Engine oil: API SJ (API SL for y2004), 6.8L (with oil filter change)
Coolant: Ethylene-glycol based, 15.4L (with fr/rr heaters)
Transmission, automatic (A343F): ATF Dexron-II or -III, 15.4L (dry fill) or 2L (drain & refill)
Transmission, automatic (A750F): ATF T-IV, 11.6L (dry fill) or 3L (drain & refill)
Transfer case: API GL-4 or GL-5, SAE 75w90, 1.3L
Differential, front: API GL-5 hypoid gear oil, SAE 80w90, 1.6L
Differential, rear: API GL-5 hypoid gear oil, SAE 80w90, 3.3L (use LSD oil for LSDs)
Power steering: ATF Dexron-II, 0.8L (total)
Front drive shaft thrust bearings: Synthetic oil & lithium soap base chassis grease, NLGI-1
Propeller shaft: Lithium-base multi-purpose, NLGI-2
Wheel bearing grease: Lithium-base multi-purpose, NLGI-2
Brake fluid: SAE J1703 or FMVSS 116 DOT-3
Vehicle: Toyota Land Cruiser (HDJ-100)
Engine model: 1HD-FTE, 4.2L inline-6 cylinder turbo diesel-engine
Fuel type: 50 cetane number, 96L
Engine oil: API CF, ACEA B3-96, 11.4L (with oil filter change)
Coolant: Ethylene-glycol based, 13.3L (with fr/rr heaters)
Transmission, manual (H155F): API GL-4 or GL-5, SAE 75w90, 2.7L
Transmission, automatic (A442F): ATF Dexron-II, L (dry fill) or 2.8L (drain & refill)
hi guys, I'm in doubt to change the oil in my 2002 hdj100 rig, 417.000 km odo, 5w40 is ok?
Thank you for this. I could have used this yesterday while searching the forum for gear oil type and amount!
For the UZJ-100 A750F transmission, I know the later units use the Toyota WS fluid. Is that the same as T-IV?
Also, it has been my experience that the drain and refill for the A343F is 4qts. The manual says 2qts. but that has to be a misprint as 2qts. doesn't even show up on the dipstick. That's been discussed on the 80 forum. I've changed the oil in it at least 6 times and it's been the same every time. It's the same in a 2001 4runner that I work on as well(I don't know the trans code for that one).
EDIT: WS and T-IV fluid are different.
Some more on that:What do you guys think is so special about the new WS transmission fluid?
