Some of you know me from my tundra v8 swap
https://forum.ih8mud.com/hardcore-corner/341445-project-effjjay-eighty-2uz-powered.html
Now this thread may sound like im whining, its more of a rant since I like to do writeups with photos and hear your feedback.
To say that so far i've found, several dare I say flaws. Would be an understatement.
Blown motor (which is why I purchased) - fixed V8 swap (priceless)
From the usual non working windows. To a 2x4 block custom shaped and drilled/zip tied into the inner door skin to hold up the left rear window. Some of this is usual for a used rig with an unknown past with a PO.
Also not uncommon locker motors not working - fixed
Now the next saga begins - Axle rebuilds at the front and rear.
I heard a noise and experienced some unusual vibration from the front and rear. The rig has started unusually darting side to side. Acceleration results in drifting to the left and deceleration results in drifting right when on a flat road holding the steering wheel straight.
Then monday night. The dreaded clunk. (seriously are you going to make me do this ? what a costly month this has been)
Jack up the front to find that im able to move the front wheels almost an inch at the 12 and 6 o'clock position. Gawd damnit
I pull the wheels and brakes. Then onto the drive flanges in which every single one of the 12 studs is stripped and the nuts are stuck on and needed to be removed with a slide hammer... only to confirm my suspision.
The spindle nuts backed all the way off to the last thread on the spindle. So they are f***c'd as are the bearings, rotors, pads and who knows what else. I was told the front end was rebuilt several months before I purchased it. Looks like a botched job
The nut backed off
The bearing riding on the washer
The inner bearing riding where ever the fawk it wanted, thus causing a "new" variable surface. Discoloration and heat spotting are hard to read but are prevelant
The nut backed off
