So Steve your saying the running boards are like diamond plated. Never seen a short one that way. All mine are flat with a ring around the edge to hold the pad down and is held on with screws and nuts. Does the front that bolts to the fender look factory? If it does I guess this something for non USA again. I guessing someone took a newer longer one and shortened it. The rubber pad was used until the mid 69 model FJ40 then a piece of diamond plate was spot welded to the top. Around 74 or 75 they changed to one piece where the diamond plate is just stamped into the running board. Is the Diamond plate spot welded to the step or part of it? If it is part of it I'm guessing it's a shortened new one.
Check out the tread about the rubber pad. What do you guys think about a group buy? The pictures that Landpimp (John) posts are the same material as some of my running boards.
Wait a minute what does this have to do with 100 anniversary High Lift Jacks
John
