- Joined
- Dec 11, 2004
- Threads
- 29
- Messages
- 1,435
I went throught he FAQ yesterday and have to give Props to Landtank's thread about diagnosing front axle issues. Fantastic info.
A little history: 94 120K OME 2.5" newly installed on 33s. I ordered (Thanks Dan!)the whole front axle servicing parts list to include wheel and trunion bearings, rotors, and 100 series pads. Nothing is leaking, just good ole PM.
I have had for about 3 months a slight rubbing (whisper) noise that coincides with each revolution (sometimes) of the DS front wheel. I thought it to be a slightly warped rotor, and the noise goes away when the brakes are applied. I really have no sensation under braking that the rotor is warped badly at all. I can feel it, but it is not critically an issue.
I thought the noise could be a result of a slightly slow or non-releasing caliper. I've mentally almost talked myself into installing new ones, or at least researching rebuilding mine with 1/2
skills.
I have not dove in yet because of a lack of tools. I've gathered up a torque wrench, snap ring pliers, some new sockets, etc. I do not have a fish-scale or calibration tool that Jim suggests.
More importantly, I've only half-heartedly looked for a 54mm socket with no success. (2 auto parts stores, and Sears)
Yesterday the noice got worse. I only drive about 15 miles a day.
I'm thinking the wheel bearing are loose. Can that cause some of that noise? It will also go away when turning the wheel slightly right on curves, and then comes back when I straighten out.
Without even jacking the truck up, I do have movement from the 12 and 6 O'clock position. None from the other side, but I can hear the DS making a clunk when rocking the PS front.
I have other transportation. I'm worried that I will be causing spindle damage or failure.
I need feedback and will be happy to further describe the condition if warranted.
I guess I need to IMMEDIATELY find a 54mm and go in and check the DS wheel bearing.
I had planned on doing the front axle service Memorial Day weekend, and having the tools on hand by then, but I think I may need to park it.
I have a NAPA (closed on Sundays, but I don't recall them having a drift or 54mm last time I checked) and an Advance. I'm an hour away from anything else.
What say you?
skills.I have not dove in yet because of a lack of tools. I've gathered up a torque wrench, snap ring pliers, some new sockets, etc. I do not have a fish-scale or calibration tool that Jim suggests.
What say you?
