Of course no other Selectro Hub removal looks like my hubs. The screws around the outside of the face were simply screwdriver removal. While the hub was full of grease, once that was cleared out I was able to find the wire lockring, simple screwdriver removal again. Once that wire comes out you get the splined hub and spring. However, as you can see in the picture, there are no cone washers to be knocked free, just remove the nuts and lock washers and the hub body is free, but can't be removed. The nut in the center of the shaft needs to be removed, however, since the hub is in the "free" position, I'm just turning and can't remove. Need to see two things, #of splines on shaft and size of nuts retaining wheel bearings. All other pictures I have seen of Selectro hubs have screws on the outside of the body, the whole unit looks different from this one which really looks more like a Warn. Help please.
