Hey guy's I could use some help...
The 1996 Lx has 187000 miles. The exhaust needs to be replaced. I have a hole 1/8 inch hole in the seam of the 2nd cat converter.
Here is the issue... The studs from the cast manifold to y pipe are seized. I have hit them with creaping oil for about 2 weeks and tried an electric impact wrench and a 2 foot breaker bar. I have tried tightening them and then loosen them. The studs are not moving. I open to any suggestion. I would really like to avoid pulling the cast manifold from the head. It will add a lot of time to the job and with my luck one of the manifold to head studs would strip..
On the side, I will be replacing the OEM system with the Bosal system from rockauto. I have the system here and it looks OK, but not as good as the original system by a long shot.
Thanks for the help.
