Seeking PN - Replacement clutch slave hose
Redline70
Riyadh, KSA
Hello folks,
Anyone have a superseding PN or high confidence fit to replace the rubber clutch slave hose on an 1998 FZJ70L-MRUV? The original, 90931-01099, is NLA. It is ~340mm long. Thanks in advance for any help!
Cheers!
96940-33405 is a brake hose which is 340 mm long.
this is the replacement fzj hose but appears to use different routing.
(image here)
$12 at amayama plus some freight and Tariff from japan.
here is a factory hose us for image
better than $96 from sketch party for a "factory" one.
Hello,
Maybe this one can be useful: 9094702F41.
It is for a newer model, so it may or may not fit.
Hope this helps.
Juan
And to be clear, the brake hose has the same fittings as a clutch hose. I've seen some clutch hoses with 'clutch hose only' printed on, so perhaps the brake hose is stronger than the clutch hose. The bake hose comes in various lengths, I have -33005 (300 mm), 33805 (380 mm), 34305 (430 mm) and 34405 (440 mm), so you can see the pattern of length in the part number.
