Just picked these up to give my 82 FJ60 a little modern flare . Haven’t had a chance to install yet but I’m hoping they drop right in and works well. Has anybody else used them ? I didn’t go LED because they seem like a headache .
They will probably work, but my advice... Return them and buy 81110-60P70
No point installing halogens that are not Toyota parts with upgraded wiring.
Just updated my previous post. Sorry I didn’t include right away.Send me a link I’ll look at it
Available at your local dealer.
Give the dealership that part number. The description in their system sounds like one light but it’s literally all those parts. Totally worth it.
Pics of them here. Post #810
ROTM- klinetime574
Got some :wrench: time in the garage tonight. Finished up the inside. The radio accessory power and ground now are butt connected straight into the factory wires. Got all inclinometer wires tied into my radio wires. Used splices for that on the radio harness (not the factory wires). I couldn’t...forum.ih8mud.com
That single part number gets you everything.
With anything other than LED you'll need a harness upgrade so you don't melt the connectors or possibly fry wiring. The Toyota # given comes with a plug-in harness.
If you only run the 55/60 watt bulb the stock harness won't have any issues.
Halogen H4 bulbs produce a LOT of heat, a lot more than the stock sealed-beam. You will melt the connectors that plug onto the bulb if you use the stock ones; they're not designed for the high-temps... At minimum, if you switch to Halogen, you need a ceramic adapter.
Try ebay....I just did and it was 54 plus 18 shipping. Pretty sure it is from a dealership not far from me, but I dont like to run around for parts so it is worth it. My headlights sucked really bad when I got mine and I traded out the sealed lights only and not they just suck. Hoping with the new wiring harness it will be brighter...we will see.$74 shipping. Ugh.
Tried a different site and it was $112 shipping.
I might actually try our local ‘MSRP + Market Adjustment’ Toyota dealer...
