f
Probably not related.
Search efi fuse.
Wish you were near Atlanta, I'd help you out.
One thing that stopped my engine from firing up was the cam position sensor plug being not plugged in completely. It started as an intermittent issue and finely ended in a full blown no start. For some reason that plug can be very difficult to fully engage the lock. I'm guessing when the dealer did the timing belt the tech didn't get it locked completely and over time it worked its way loose. The way I found it was from the trouble code and then I just wiggled the wires and it feel right apart. Have you checked for codes yet?
OK ..... so .... my bad car week continues.
After admitting ignorance to the multitude of advice on here that the T junctions in the cooling lines should have probably been my first replacement after buying this 99 LX with 200k miles on it; and them busting on me and costing me a couple hundrend bucks to fix last minute and several lost days of work this week...........
.....after picking my LX up from the mechanic that replaced those broken cooling line parts yesterday, I drove the LX from the mechanic to the grocery store, grocery store back to my house - both times it started up fine (as it always has, started right up on the second or third turnover). I parked it in my driveway and did not get in it until today / just now.
Tried to start it and it will not. the battery is fine, it's turning over as fast as it ever did ... but will not kick in and start up.
I realize this is usually a question that is WAY to broad to answer however ... was thinking that, based on the data available which is that, until yesterday, ive never seen or heard anything symptom or warning of such a problem coming on; and the fact that it started immedicately after someone was working on the cooling system lines that busted a T joint ... well, maybe was hoping someone had insight as to what in that process could have caused this and/or maybe if this just suddenly happening without any warning or symptoms leading up to it is an identifiable problem in itself.
Any thoughts or ideas appreciated.
Had not one but TWO first dates lined up this weekend ... one of them friggin gorgeous and ... well, this could change my LC/LX enthusiasm here - this isnt just missing work anymore
help please !
Its not getting fuel.
My money is on a clogged fuel filter, when the tow truck picked it up/dropped it off it went at a extreme angle to go onto the flatbed and sediment from that moveda round, got mixed into the fuel and clogged the filter.
Bum a ride to AutoZone, if you do not have wrenchs buy them when you get the new fuel filter.
The fuel filter is on the drivers fender. Takes 15min to replace, a new filter costs $15.
UBER your 1st date your place and have her help you wrench on your truck, then cook her dinner. If she sticks around for breakfast, that will confirm if she's worth dating a second time.
Edit: OK...humor set aside and focusing on the Technical side of this thread:
Start simple first:
Key fob battery: Is your key fob battery dead: does your security light still flash after you put the key in?
Check Engine Room Fuses: Covered Box Next to battery. Under the cover of the box is a diagram of all the fuse and relay locations.
Check Immobilizer Circuit: Is it functioning properly: read here: My immobilizer fix
Turning into tw or jp forums...
