searching for transmission cooler lines fab writeup (1 Viewer)
someone did an awesome job of detailing their cooler line fabrication which I did not bookmark like a dummy
I think it is in the middle of a build hence search not helping
Does anyone recall this writeup?
Last step left in a big "while you're there" that began with addressing a leaking radiator
Thank goodness the time spent working on your LC doesn't come off your life total count -
1. Buy some hose
2. Buy some clamps
3. Buy some protective braidy stuff, optional?
4. Cut to length, install
5. Step back and admire your craftiness
1. Buy some hose
2. Buy some clamps
yeah, there's that -
this writeup had some great research on different hose psi/temp specs - finding that some local shop transmission hose was probably not up to the job - that 's the info I'm looking for, should have been more specific
Bingo
Guess I needed the magic woid “hoses”
Some good information in that thread including your contributions effjay
Thanks
I'd recommend constant tension hose clamps if you're that worried about the hose holding up.
This job pegged the profanity meter in my shop. :)
I thought I’d pegged the meter with the PHH and its brother
Good times
But found a workaround for the no-longer-available-formed-right-angle-hose-so-you-have-to-use-a-unicoil
Good times
