You buy a new clockspring. Also called a spiral cable.
They list for ~275 bucks.
84312-12040 does not apply to an airbag equipped vehicle. You will need to replace the spiral cable or the combination switch assembly.gents.
got referred here. i was going in to replace a plunger since my horn is not working. now i'm under the impression i have the wrong part.
is there a fix or diagnostic for a non working horn in a 97 lx 450? i cleaned the horn ground and checked the fuse. i am pretty sure i would have swapped out the fuse.
also how does this thing come out? i'm not seeing it in the FSM.
thanks in advance.
hi dan84312-12040 does not apply to an airbag equipped vehicle. You will need to replace the spiral cable or the combination switch assembly.
hi dan
thanks a lot. i googled the spiral cable/clock spring and i can see how to take it out now.
i am gathering that at 225 K there is no reason to try any further diagnostic? or is there any diagnostic i can run?
or which part was the combination switch?
i'm really only in there to fix a sort of not working horn. meaning at one point if i moved the "pad" around i could eventually get it to sound. but right now no horn.
any good ideas please?
