- Thread starter
- #101
Waiting on parts to start mechanical work (Timing belt w/fan bracket, PCV valve & both hoses, spark plugs, heater Tee's, fuel filter, air filter, intake manifold gaskets, T-body gasket, thermostat, Power steering HP line, drive belt idler pulley & tensioner pulley bearing, wheel bearing service, new front drive shafts, new hub flanges & cone washers, complete rebuilt of stabilizer system, rear coil springs and other stuff ....)
I've been doing some lite stuff meantime like:
Finishing up carpet stain removal.
Continue working on perfecting body paint.
Replacing and condition all interior plastic molding & seats.
Working on DVD Parasitic Battery Drain drop down DVD
Removed SAT radio antenna.
Undercarriage broken bolt removal.
One main bolt for #2 plastic under shield was in No. #3 crossmember was broken. I found it easier to just replace No. #3 with one I had lying around. Cleaned up all 7 bolts of No. #3 cross-member & front differential support coated with marine grease (MG). I subsequently de-rusted then painted No. #3 cross-member & frame mounting point with POR-15. See page ~#10 Front Differential bushing replacement, and only packed bolt holes with MG.
Differential Support While in area I took a look at bushing of front differential which I believe are fine and saw nothing remarkable. Yes they move more than new but that is to be expected. There is no detectable clunk from bushing. Subsequently replaced all bushing see Page #10.
