All of you have more experience than me - I appreciate everyone's input. Sounds like I have some work ahead of me.
do yourself a favor and get a decent multimeter
Lord, you do indeed have a mess on your hands! It can be fixed, but you MUST do some basic protection stuff before you have a harness fire.
Electrical lesson #1 : The solid white wire that currently runs to the battery should have a fusible link installed. A fusible link is nothing more than a wire that is 2 gauges smaller than the wire it is protecting. In this case it is a 14ga wire. It is wrapped in a heat resistant insulation. It is generally about 3-4 inches long, so even though it's two gauges smaller, it dose not present a large amount of resistance to the power circuit. It acts like a very slow blow fuse. It will allow the entire system current to flow without melting. However, if you dead short the main charge wire it WILL melt BEFORE the larger main charge wire, thus saving the harness from a fire.
You need my 72-78 Fusible Link Kit AND the connector that attaches to the white wire coming out of the harness.
Electrical Lesson #3: The large White wire with Blue strip is the alternator B+ wire. It comes off the back of the B+ terminal on the alternator as a 10 ga wire, runs into the main harness where a smaller 12ga White/Blue wire is spliced to it. The 10 ga wire feeds the output of the alternator to the AMP Gauge - terminal. The smaller 12ga White/Blue wire goes to the AM terminal on the key switch. The charge current goes through the meter (causing it to read + or - ) then on to the + side of the meter where the 10 ga solid white wire attaches. This solid white wire goes to the fusible link then to the battery +. The fusible link protects both the 10ga White and the 10ga White/Blue wires. Because it is so short in comparison to the longer 12ga White/Blue wire going to the key switch it will also protect it. What is not protected by the fusible link are the smaller 14 and 16 gauge wires that come off the key switch going to the fuse panel. If you get a short in one of those wires they will melt... period....
OK so the very first thing you should do it get the fusible link and connector. The second thing you need to do is get a red 2ga + battery cable and run it from the battery B+ to the starter. Then get a black 2 ga - battery cable and run it from the battery - to the frame. Then get a shorter 2ga black jumper cable and run it from the same point on the frame to a point on the engine block. This will get your grounds the way they are supposed to be and if you get the military ends will allow easier connection of accessories to the battery.
If your setup as it is, is charging the battery with the two pin plug to the alternator unplugged then you have a internally regulated alternator and can get rid of the voltage regulator. To verify the alternator is charging: Turn on the headlights for 5 full minutes. Turn the head lights off. Set your volt meter on DC 20 volts. Put the red lead on the battery + and the black lead on the battery -. Write down the reading. It should be between 12.7 and 13.2 depending on state of charge. Now start the truck and repeat the measurement. It should read between 13.0 and as high as 15.2 volts. It should gradually drop as the alternator charges the battery. If the reading is the same, or lower than the first reading, the alternator is not charging. If it consistently reads higher than 14.8 or higher then it is charging but is not being regulated.
So do all that and THEN you can start cleaning up the other messes...
It doesn't look that bad as most of the non-stock wiring is associated with the alternator. The alternator is probably not producing as it is externally regulated and it is not plugged in. What happens to the battery voltage when you plug it in?
For the stock wiring all of the power that goes in and out of the battery goes through the amp meter (except for the starter motor). That means that there is one wire at the battery + besides the starter motor cable. This wire should have a fusible link to avoid the possibility of a harness fire.
I bet the alternator is NOT charging. Determine if it is, because you can't proceed with cleaning it all up until you know if it works or not.
If it is not charging as it is, plug the two pin connector into the alternaotr (connecting the regulator to the alternator) and see what happens. Alternator could be bad, and/or the regulator could be bad.
The actual wiring depends on the specific alternator. Many used switched power to engergize the alternator. Some require a diode in the circuit to prevent feeding back power to the ignition after shut off. Some need a light bulb or resistor.
So while I have peoples' attention -
I've been digging around trying to figure out how best to wire in an internally regulated alternator, and it looks like it would be pretty easy. In fact, it seems like, with the external regulator currently disconnected, like it is - that's pretty much what I have.
Simply put - It would wire up to something like this, correct?
Only thing I'm not sure about is whether I can hook the voltage sensor up to the battery. I've heard it's not a great idea just to jump it over to the BAT cable on the alternator because then the alternator won't account for voltage drop through the lines...but I'm not sure hooking it up to the battery is the right answer either...
I'm pretty sure I should just be able to leave the "warning light" terminal naked, since there's no warning light to run it to.
Thoughts?
