I just wanted to show my finished project. I installed a Scion T1806 with color change. I purchased the head unit from ebay for $45 and an Ipod cable from a different vendor for $14. Both had free shipping.
I did not take pictures during the project but here's what I did.
1. Unplugged my amplifier behind the right dash speaker. Went in through the glove box.
2. Removed upper dash surounding radio
3. Removed my old radio/disc/cassett unit
4. Saw dust around the vents so I took that apart to clean it. Also created new axis (axel) for vent to turn on since old plastic one broke long ago.
5. Saw dust around instrument cluster so I took that apart to clean it. (requires steering wheel removal). The clear plastic in front of the gauges was hazy and scratched up so I used my headlight restoring kit from 3M on it and it turned out like brand new! I also replaced the main light bulbs since they were dim with age. Check all the other bulbs and found one warning light was burned out!
6. Trimed the dash. Lots of plastic removed but I just gritted my teeth and did it!
7. Removed all the buttons that come out from the upper dash and decided I would paint it camo-green.
8. Had to remove the lower dash to prep and paint it camo-green too so they would match.
9. Cut my brand new Ipod cord so that I could run it through a small hole in an unused dash knock-out.
10. Mended the Ipod cable by soldering all those teeny tiny wires back together.
11. Plugged the Ipod cable in the back of the Scion along with the two previously unused Toyota plugs. Bent the connector that was plugged into my old unit back and away.
12. Cut the blue antenna wire from the Toyota harness.
13. Replaced the gauge cluster, upper dash, all the switches and the lower dash.
14. Enjoy some fine 80's tunes!
