Schwitzer Turbo 3B BJ42
Perth Australia
G'day
After obtaining all the bits and pieces I wanted to turbo my BJ42 I have got around to installing it all; even though I ain't finished :-)
First thing I did was to remove my second battery and the air box. Next I removed the engine pipe and luckily no hassles with the bolts and nuts from the exhaust manifold.
I got a disk machined so I could mount the turbo manifold on the engine without hooking the turbo up. I then drove it down to my exhaust guy to put together a pipe for me (2 1/2" with muffler). Pics with the manifold with exhaust installed
The next job was putting the turbo in. Pics of the block off disk removed from the manifold and the plumbing points used. I plumbed the oil feed through the gallary off the back of the block and the return via the alternator return.
I then disconnected the edic motor and locked the IP in the off position to turn the engine over without starting it to ensure there was oil to the turbo and it was flushing properly. Finally I hooked up the air box, cross over pipe and the drain hose and fired her up.
