Scan tool what is everyone using and what do you recommend for 2008 Tundra 5.7
Hogan
Three on the Tree
Forest Lake MN
I have the ABS light on with traction control, 4Hi and one or two other dash light flashing. I have had this happen a couple times before and have taken it to the deal to get it fixed. Usually it's a wire chewed up by a little beast. I have visually inspected the ABS sensor wires and didn't see any damage. Instead of paying the dealer to scan it I figure I can purchase a scanner and do it myself. Any help would be appreciated.
I use a Mini-VCI cable from Amazon and a copy of Techstream from the walk through on Mud. You can’t beat what the manufacturer is using. It’s a bit touchy to get it up and running but once it is, it can do anything Toyota can do.
Thank you
I will say this, when you buy one of the Mini-VCI cables, it will likely come with TechStream on a disc… I would not use it. Perhaps it’s just paranoia, but anyone can put anything on a disc and then screw you solidly with hidden execution files. The copy that is here may be the older V12 instead of V18, but it is also verified as not some scum filled sh!t file. I have had no issue using V12 on 2000 LC, 2014 Tundra, 2016 4Runner, and 2018 Tundra models.
Thanks
