SBC High Altitude Carb Jetting (1 Viewer)
Rockets2000
Space Cadet
Houston, TX
I live in Houston and am planning a trip to CO this summer to hit the Alpine Loop and surrounding trails. My '72 40 has a 350 with a 600 cfm 4 bbl Edelbrock (Weber) carb. Will I need to re-jet to lean out the mixture at altitude? If so, what size jets/metering rods should I go with? What do you CO guys run?
Thanks!
Unless it's already a tad on the rich side at sea level, I'd try it as-is. It'll make it. Otherwise, maybe 1-2 jet sizes leaner. Carbs are pretty good at compensating for altitude; most guys run what they have and accept it.
Cdaniel
Undocumented Mechanic-Not CDAN
AZ
Run it
I've been from Phx to over 14k elev near Ouray and my Q-jet handled it.
You'll notice a difference in the way it runs though.
OC, CA
I would leave it. It isn't going to hurt it running a little rich. If you lived there it would be a different story.
Rockets2000
Space Cadet
Houston, TX
Thanks for the info guys. It is a tad on the rich side already, so I might go 2 sizes lean and see how she does.
pb4ugo
spay-lay-wi-theepi, Ohio
I've been out to CO a couple of times. You'll be good w/advancing the timing, when needed. Youll be able to tell when. I advanced timing until I got back to a good idle. On my Qjet, I also found limiting the movement of the power valve helped alot too, especially in then upper elevations.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
