Sbc Hei Simple Wiring Instructions
I searched up a simple wiring diagram for a Chevrolet 350 and a HEI Ignition earlier and now I can't find it. Does anybody have the link or simple instructions handy for the coil, battery, ignition, distrributor, ect?? This will be to wire up a 350 in a 71 FJ40
Thanks:crybaby:
Tankota,
I just purchased a 1971 FJ40 with a 350 in it but nothing wired up. The coil is not in there and there are no plug wires. I just need to know what goes to what as far as wiring. There is a wire coming from the bottom of the distributor. Where does this hook up to? I don't mean the plug wires, I have that firing order ect. I just need to know the rest. I found a thread in here yesterday that had a simple diagram. I just cant find it again.
Thanks
Is it a big cap HEI distributor?
If so, the one wire (or just a empty spade connector) coming from the terminal marked btty goes to ignition hot. I believe that to be black with a yellow stripe near the factory coil location on the right inner fender. The terminal next to it marked "tach" goes to a tachometer if you want to hook one up. The 3 wire connector that goes from the cap to the distributor is the wires from the pick up and module to the coil.
If it is a small cap with one wire coming out of the distributor it is a points distributor and should be thrown in the bushes and replaced with an HEI. That one wire goes to the negative side of the coil with ignition switched battery voltage to the positive side of the coil. Really HEI is cheap and simple and works loads better than crappy old points. It sounds to me like this is what you're seeing.
If it is a small cap with two weatherpak connectors, one four wire, one two you have a computer controlled fuel injection distributor that requires a computer to advance the timing. The two wire connector goes to the coil, the four wire to the ECM.
