sbc electrical problems
Any electrical wiz's out there?
I have a sbc in my 40. When I replaced my alternator a while back my battery started draining down every few days.
I wired it like the instructions said and it starts and charges ok but the engine will not shut off when I turn off the key.
If I turn the 2 prong plug on the side of the alternator around it starts, charges and shuts off but it is also draining the battery.
I determined this by putting a light between the neg terminal and the wire and when I unplug the alternator wire the light goes out.
HELP ???
Thanks
ok i will try to help, i did this about a year ago on my 76 FJ40 W/V-8 and internal regulated alternator, 10 gauge white wire with blue stripe (from your amp guage) to the battery terminal on the alternater (large threaded terminal on back of alt) and the other 12 or 14 guage white wire with blue stripe to the #2 post on the side of the alt (feild i beleive, furthest one from the threaded conecter on back of alt) the other post on the side of alternator (closest to threaded terminal) gets a jumper wire from the threaded post on back of alt. the other wire (12 guage) white with black stripe not used. and now the factory voltage regulater on the firewall can be removed, but you have to take the black wire with yellow stripe and the white with blue stripe and connect them together and thats it. hope this helps and if anyone has other ideas please post. GOOD LUCK!!
This sounds like the way I have it wired now.
I am not sure about the yellow wire though.
It works fine as far as starting and charging but when I turn off the key the truck continues to run.
Are you using something like an MSD CD ignition box? If so the tiny amount of current allowed to flow from the charge indicator to the ignition is sometimes enough to energize the box and allow run-on. The fix for it is placing a diode in the line.
To test it, disconnect that wire from the alternator (#2) and start it up. It will not begin charging at idle ... you will need to wind it up to 2500 or 3000 RPM ... then the field will energize and begin to charge even when the RPM's go back to idle. After you have it charging shut it off ... if it shuts off you found the trouble
You may need to put a diode in line with the field (?) windings. There was a discussion on this here a while back. If you can't find it I will go check which wire it went to.
Search sucks so you might need to look manually. The power feedback is enough to keep it running. If you hook the keyed power to the internal reg to a seperate keyed circuit (I think Chevy trucks use the heater circuit) you eliminate the feed back and engine shuts down properly.
Once I turn off the key the power on the keyed wire goes to 0 volts.
Still checing it out.
Thanks for all the ideas.
Chris
