I've searched the forum but I'm stuck. Here's the background.
The PO did an SBC conversion but to say that it was done half ass is an understatement. I'm slowly picking away at all of the problems. I replaced the battery stand and a couple of wires from the alternator came out of there connectors. After hooking everything back up my I almost got stranded on the side of the road when my alternator quit(I thought). I took the alt in and it checked out ok. From what I can tell it is an Ac Delco 3 wire alt. It had only one wire from the plug spliced into the wire off of the lug in the back. I have since simplified this and jumped the wire to the lug as you can see in the pic. The wire from the lug runs back and and hooks into the starter.
Couple of questions.....1. Is the other pic the regulator? It is still connected. If the regulator went bad would it cause my problems even if the alt has a built in regulator. Should I just unplug the stock regulator?
2. Should I disconnect the alt from the starter and just run it straight to the battery?
Hopefully that is as clear as mud. Fire away.
