Les Summer
I thought this might be useful, so here you go. Would anyone, has anyone tried this product?
it is best to avoid rubber according to the back of the can, like you said. Glad you mentioned it, I might never have checked. It also says may soften some vehicle undercoatings and to check with manufacturer. I am not sure what that means, but does not sound good.What is it? Lanolin based? Silicone? Notihing prevents rodents, used to work at a lawn mower shop and have seen every method tried but hey it can't hurt.
Probably try to avoid getting it on any rubber parts if it is oil based and will cause swelling.
Soak it on a rag and rub down metal frame and other areas of rusty concern. Of course if it is already super rusty there isn't must any spray on solution can do
That is just general advice any petroleum based product will say, but it's good to follow the advice and keep away from rubber. Silcione lube is OK on rubber. WD40 and other oily type stuff is best for metalit is best to avoid rubber according to the back of the can, like you said. Glad you mentioned it, I might never have checked. It also says may soften some vehicle undercoatings and to check with manufacturer. I am not sure what that means, but does not sound good.
As for rodents, peppermint is tried and true with getting rodents to move on if they happen to try to move into your vehicle. I think if there is already an existing rodent problem, rodents have already made a home, then yes it's probably difficult to get them to leave. I did a lot of content research on the topic recently, and the consensus is peppermint oil works great, but flashing lights and ultrasound devices are a scam to avoid.
leaving anything in one spot for too long is absolutely a big one too. I parked in a city lot for 15 years. always near a dumpster. I recently bought my Land Cruiser and started to let my subaru outback sit in the lot for longer than normal, only by a few days, and just like that, there was a rat rave under the hood of the subaru, and my wiring harness was destroyed. so now I'm just all about trying to prevent it from ever happening again. especially not to my beloved LC. luckily the subaru was on last legs about to go to the junk yard anyway. first time it ever happened was when I let the car set too long in same spot. never happened any other time.That is just general advice any petroleum based product will say, but it's good to follow the advice and keep away from rubber. Silcione lube is OK on rubber. WD40 and other oily type stuff is best for metal
I've seen everything from peppermint to hot sauce being used. You're right, once they are established nothing will stop em' But if you are just trying to prevent it, give it a try and hopefully it works. Some say keeping the hood open helps as well so they don't have a quiet dark space to get comfy with.
I hear that, yeah the environment you're in certainly makes a difference. I am lucky, out here in the woods our mice are small and timid and don't seem to mess with much.leaving anything in one spot for too long is absolutely a big one too. I parked in a city lot for 15 years. always near a dumpster. I recently bought my Land Cruiser and started to let my subaru outback sit in the lot for longer than normal, only by a few days, and just like that, there was a rat rave under the hood of the subaru, and my wiring harness was destroyed. so now I'm just all about trying to prevent it from ever happening again. especially not to my beloved LC. luckily the subaru was on last legs about to go to the junk yard anyway. first time it ever happened was when I let the car set too long in same spot. never happened any other time.
Does this product need to be applied annually (for northeast), or is it once and for all application? Thanks.I have had it professionally applied to my FJ62 by the son of the creator of NHOU. Seemed to be a good product. I sold the vehicle a few years later, but worked as intended. Had a slight smell for the first week or so, like most rust inhibitors. Once it gets a nice coat of dust, it doesnt get on your clothes.
Decent product, similar to the others out there. I think rodent deterrent is a byproduct of it being not pleasant to get on your skin or "fur"
annually for sure.Does this product need to be applied annually (for northeast), or is it once and for all application? Thanks.
