At 190,000 miles the starter on our 94 FZJ finally gave out. It had been acting up for a few months but it is now dead.
Read up on all the threads about how to remove it and rebuild it etc. We took the LF wheel off, removed the fender liner and started with a 3/8 ratchet and some extensions. Could not get a straight shot with any leverage so used a u-joint, would not budge so fitted an adapter for the 1/2 inch pry bar but the u-joint snapped before the bolt would budge.
Replaced the 3/8 hardware with a 1/2 inch socket and 1/2 inch extensions and 1/2 inch u-joint fitted to the pry bar and was able to get a lot of torque onto the socket but ended up breaking the 1/2 inch u-joint as well.
Tried to fit an impact gun in there but did not have enough room.
Tried removing brackets holding things like the dipstick to get them out of the way, but still could not good access for a straight shot at the bolt that allows good leverage to be applied.
Dont see how to get any leverage on the top bolt when approaching from below.
Any ideas would be greatly appreciated.
Thankls
Tom
Thankls
Tom
